Template Folder was not Created on New Install
  • 19 views
  • Last reply by Charles218
Running TB 136 on my new Macbook, I transfer my old profile from TB running 128, I use IMAP. The first thing that I noted was emails in my Drafts, Sent, and Spam folders did not transfer, and the Template Folder is missing. I did the transfer by moving a copy of my TB profile to the new install. How do I get the missing emails and the Template folder?
Thanks! Charles
Running TB 136 on my new Macbook, I transfer my old profile from TB running 128, I use IMAP. The first thing that I noted was emails in my Drafts, Sent, and Spam folders did not transfer, and the Template Folder is missing. I did the transfer by moving a copy of my TB profile to the new install. How do I get the missing emails and the Template folder? Thanks! Charles
Well, I just discovered that I could create the Templates Folder by Saving a message as a template. Now, how do I get my previous templates into the new install?
